I have two questions. The first one is for myself. just tore down, solvent cleaned and reassembled some old '75 MX400 forks with new seals. After doing it I was looking at my Clymers on a couple year newer IT400, and saw that I should have used locktite on the bottom allen bolts. I didn't. Is it safe to ride for a while, or better I tear them back down enough to do that? Will I need to use solvent to get the oil off the threads enough for the locktite to work?
The second question is for a buddy. His son is riding a '73 DT125 that he stripped down, changed to a narrower seat and plastic tank, and layed down the shocks and put on longer ones. He also put longer spacers in the forks to try to stiffen them, but is now wondering if that effected his total fork travel. The front is pretty harsh, and he's going back to the stock spacers, but started wondering if smaller spacers and longer springs might give him a little more travel. Someone else told him that DT250 forks from that year would bolt on and give him more travel, but I'm thinking that the technology was the same and couldn't do much in that regard, and that he'd have to find newer forks with the axle offset. Is travel completely based on slider length, or do other factors come into play?
Thanks!
Thanks!
