ftw666
27
when i start my bike it pours fuel out the overflow tubes out of the carb for a couple seconds. then it stops after the bike starts. so i checked my float level and it looks fine. so then i checked my float needle for wear and it looks fine too. whats going on here.
antorider
17
ftw666,
It did to a large extent. Before I replaced the needle valve there was a big spill from the carb bowl overflow when I opened the tank fuel valve, now just a little bit that stops quickly. This is before I start the motor.
Antorider
ftw666
27
do know what carb you have on your wr. is it a keihin pwm 38 mm. does your choke knob also control your idle or do you have an idle screw.
