shiftmx731
- Oct 10, 2003
- 44
- 0
Ive ran into some trouble while replacing the seals on my 94 rm 125. in 92-93 Suzuki used dual chamber forks which I believe are the forks where you have to pull the damper rod in and out in order to bleed them..from 94-95 Suzuki switched to a fork that im not sure of the name, but it is all one piece inside. With dual chambers in order to get the right oil level you colapse the fork completely and bleed the damper fill again and suck out the 100 or so mm. On my set of forks I have no Idea how to set the oil level. I changed the seals, but I dont know how to set the oil height. Suzuki says I need a cylinder holder which holds the inner fork cylinder at a certain distance from the outer fork tube. if anyone can tell me how high the outer fork tube needs to be raised from the fully collapsed position to get the right height for filling/checking oil levels or If anyone has an easier way and can tell me how to check the oil level on these forks I would greatly appreciate it. thanks again..dirt rider has been my saving grace in the past!
