tinytrev
40
racetech recommend for my weight 4.754 spring rate. does any1 know wat is the closest or best shock spring rate for someone 150lb or about 70kgs.. i know its well a discussed topic but couldnt find anything that really explained the proper spring 4 me.. sorry to every1 for the continued dribble but im just learning... thank you all
McRider
82
I'm about your weight and I just installed a 4.8 kg Race Tech shock spring and it works well. The spring is longer, though, so move your pre-load adjusters all the way to the top, so you don't have to move them so much when adjusting for sag after installing the spring. Also don't forget to use the bottom spring seat that comes with the spring, rather than the stock one.
