scott graaf
- Apr 25, 2002
- 6
- 0
just took apart the rear linkage. three questions - do you use locktite on the bolts when reassembling? Second, when pushing through the rear swingarm bolt - the threaded end gathers grease. If the grease if left on and the nut re torked, does this cause the bolt to loosed vs cleaning threads and tightening. Lastly - the nut that holds the rear link to the frame is so close to the frame that you can not get a tork wrench with a socket on it. The bolt/ nut can not be reversed. Can you hold the nut and tork the bolt end or will this give a false tork reading? any tricks?
