Howdy,
I was wondering if there was any kind of trick to getting the bolt that holds the linkage to the frame out. I have been trying for over an hour now, with no luck. I got the nut off just fine, and the bolt turns a little rough but not enough to keep it from coming out. Can the bolt be bent enough to wear it wont come out??? I soaked in in PB blaster so I will leave it set over night and we will see what happens tomorrow. Is there anyway I can get like a socket extension in there, (at a decent angle) so I can try and beat it out??? Also I was wondering what kind of grease do you guys recomend using on the linkage bearings, and how do you tell if the seals are shot??? When a bearing doesn't turn smoothly/or at all, after it has been soaked/cleaned in kerosene then it is shot, right?? Thanks for the help, in advance
Ben
Ben
