Hello there everyone.....
I just went through the rear suspension on the 1994 KDX250 for the first time.
I'm having a problem getting it back together. Can't quite figure out the order.
At first I tried putting the shock on first, then the rocker arm and swingarm. The swingarm was binding up on the bottom of the shock, and just wasn't right. So then I took everything off, and put the swingarm on first, made sure it had the right articulation with the rockerarm, and now I'm trying to figure out how to get the shock in.
If this is the right order to do it in, it looks like I need to remove the airbox. I've moved everything around in there, including the carb, etc.....and can't figure out how it comes out. Even if this isn't the right way to do it, I'd still like to get the airbox out and clean it.
Anyway, what am I doing wrong here? I'm hot, confused and getting eaten alive by mosquitos!
Thanks!!
John C.
Thanks!!
John C.
