Has anyone done one of these? Can you do this while leaving the engine on the bike or do you need to fully disassemble and split cases.
I have seen a procedure to get the left side (flywheel side) seal out using a drill and sheet metal screw, not sure if it will work on the right side.
Thanks for your help.
