not to sure if JB weld is what I would of used, there is an epoxy (forget the name) that many use for inside/outside the cranks. The JB may hold up for a little but cant count on it
Having a serious problem trying to get the nut off !
I’ve tried a penny in the gears after heating it up
Tried hitting it with air ratchet
Suggestions!!!!
How do I know if that seal is junk??
I was told from person I bout the bike from
It blew out a whole quart of oil at top off casing but think that was from faulty gasket
New piston n rings were installed recently
