Rm85 water leak into tranny oil...?
Shiffti09
:bang: There is water leakin into my transmission oil. The oil is a grayish color. I emptyied it out put brand new oil in rode the bike for 10min and the oil was turned gray again! What could possibly be leakin into the oil? Its not an external leak from the radiator or cracked housing because outside was dry and I did not ride through water. So there must be a seal broken our gasket worn somewhere? What are your suggestions?
sharky243
246
You need to re-build your water pump. The seals, bearings and possibly the shaft all need to be replaced. This should solve your problem !!
