Never been a problem with mine on a WR400. What bike are you riding? If it vibrates a lot, I am sure the loctite would work fine... Make sure your damper is sitting flush on the clamp, and does not have dirt or debris perhaps that you are tightening against, that then vibrates out, and leaves the damper loose. Other than that, loctite away.
