I just bought a used 5x8 Cargo Mate enclosed trailer, and am in the process of setting it up...So many options!
Right now the trailer has no D-Rings or tiedowns anywhere. Talking to a friend that has had an enclosed trailer, he told me to install D-Rings on the side walls of the trailer instead of the floor. He said that way there is no downward pressure on your forks. Made sense to me...but that brought up some questions. What type of fastener do you use for D-Rings if you put them on the walls? Do you just use a good size sheet metal screw through the plywood and into the metal wall support? Will this hold? I'm hauling 2 bikes (RM125 and KX250). Any suggestions would be appreciated. I'm planning on buying the cheap $20 steel tube wheel chocks.
Also, looking at putting in shelving / baskets, etc. Anyone have any really handy ideas?
Thanks!
Thanks!
