whenfoxforks-ruled said:You need to check the return spring, and the star/fork orientation in neutral. And check the 2 spring loaded detentes that hold the drum in position. Vintage Bob
You're as fussy as me. However if the shift lever is soft enough he may have got away with it.whenfoxforks-ruled said:I would be looking for a new shaft and seal, keep the old one just in case? Vintage Bob
Yea, I have had to learn not to be as fussy as I would like to be, as at times it can be needlessly expensive. So if there is no obvious damage I would leave it alone to.sr5bidder said:If it ain't broke screw, with it till it is :laugh:
