I've got a 1989 KX250 that I just rebuilt from the ground up. After putting the motor and rest of the bike entirely back together I must say that it is a pretty good bike now. But I've got an annoying leak coming from the shifter seal.
I've put two seals in now and they both seem to be leaking from around the seal. The shifter shaft does have some wear, but it doesn't look like oil is coming through the seal where the shifter shaft goes through, but rather is coming through the mating surface between the seal and case.
I'm guessing the case is a little out of round?
Anyway, does anyone know what I can do to get a good tight seal between the seal and case? I was thinking of using either JB Weld or maybe RTV before pressing in the third seal, but thought I would check with you guys.
For those that care, here are before and after pictures:
http://members.tccoa.com/micahdogg/100_3864.jpg
http://members.tccoa.com/micahdogg/100_3900.jpg
Micah
Micah
