Originally posted by XR400RMan
I'm the same way as LWilson250, It takes no time to pull the clutch in and shift,I mean why don't you guys go ahead and use it, You to darn lazy, I don't see the big deal on shifting without the clutch, I mean you do everything pretty much at the same time anyways(Let off gas,pull in clutch and shift). YOU WILL NOT BE ABLE TO SHIFT WITHOUT THE CLUTCH FAST ENOUGH THAT IT WILL DO YOU GOOD,Just use the darn clutch, Thats what its there for, Maybe you need an Auto clutch if you don't know how to use it, Matt
If you do it right shifting without the clutch doesnt hurt much, if youve ever driven any sort of car/truck without a synchronized transmission you know how to do it,
One thing youve got to understand is a dirt bike transmission is constant mesh. you never take the teeth of the gears out. Each some of the gears have pins and some have holes and they slide on a splined shaft, a
RICKYD:Everytime I ride I want to get better also and I have been, But shifting with the clutch does not take enough longer than shifting without it to make a differnce in my opinion, If I went out today and got on a dirt road and took off and did not use the clutch when I shifted and then the next time I used the clutch I don't think I would have accelerated any faster the time I didn't use it, There is no reason to not use the clutch, I get better everyday but I still use the clutch, Its like your saying if you use the clutch you won't get any better,Rubbish. I don't have anything aginst you but I and others have tried to make our point clear, If you want to tear your tranny up then go right ahead,Nobody here will feel sorry for you when you grind your teeth up, Matt
