Should I buy a heavier rear spring?Im 6'2 280 And I ride a 125!
CR_RIDER
126
Yeah I like to jump and with my size and weight I bottom out really bad.Could the bigger spring fix that?How do I determine which spring is heavier They are weighed weird.
bclark001
230
it should make a big difference. maybe just start with the rear and see how it goes
does the front bottom out? did you crank up the compression clicker?
CR_RIDER
126
Im not reading all that.when It comes to suspension nothing makes since to me.All this race sag.preload,compresion.I just dont get it.I mean I can turn a wrench.But just dont no nothing about suspension.I need a suspension book for dummies...lol... :laugh:
bclark001
230
there is a brass flat head screws in the top of the fork in the center and same on the bottom the top is for compression (how much resistane to compress the fork) the bottom is rebound (how fast the forks kick back to normal) and the same applies for the shock in the rear there will be a brass flat head screw toward the top and one on bottom they should be on the right hand side (i think) go through the guide and let me know how it goes im leaving work rite now (i must be working hard huh LOL) but ill check in when i get home in about 30-40 min
read up on suspension on mxtech once you figure it out it is pretty easy and it makes such a difference its amazing you will instantly be a better rider with a good setup and when you get your baseline (WHERE YOUR CLICKERS ARE SET AT STOCK) just move them 1-2 clicks at a time and write down how many clicks you turned and you will get the feel of what works better
check these threads out also
http://www.dirtrider.net/forums3/showthread.php?t=156861&highlight=rebound
http://www.dirtrider.net/forums3/showthread.php?t=18889&highlight=rebound
bclark001
230
its the screw off center and the FRONT WHEEL NEEDS TO BE OFF THE GROUND loosen the screw all the way out wait for a few secods then put it back in
CR_RIDER
126
Ok I bled the forks.I could hear the air coming from one side.How long do you have to wail until you put the screw back in?
Rotorranch
436
CR_RIDER...you really ought to read the links provided. You will came away with a better knowledge of suspension. :nod:
Knowledge is a GOOD thing! :cool:
Rotor
