woodsguy2000
- Apr 24, 2001
- 192
- 0
I have a 99 CR250, just put new chain/sprockets on. Noticed some chain rub on case. Was this from worn out chain or maybe needing a spacer on shaft due to oring chain. I believe I have heard of this on the 450's. If so what size washer do I need?
Doing a search on here shows the same topic about a year ago, basically said no spacer, so the rubbing I had from old set was from them being worn out and having too much side play?
Thanks Rob
Thanks Rob
