- Nov 25, 1999
- 7,926
- 43
I'm putting the Spode Wash together this afternoon. The setup will have a 200 gallon tank on steel supports. The water will be gravity feed to the water heater and the shower stalls. What I need is a transfer pump. I will have a second tank in my truck. I will go into Stillwater and get water then will need to transfer the water into the other tank. I can puchase a 110v pump for $40. If someone has one and will be at DW all week could you bring it. The small 12v pumps would likely burn up from the use(low volume). I have $100.00 in this deal without the tanks. I will buy one tank and try to borrow or rent the other one. I will use the tank around my place when DW is over. Any help would be appreciated.
