bigboss_an
- Sep 21, 2005
- 36
- 0
Hello Everybody,
Been working on a friends' (1990) CR125. Bike has been sitting for about two years. Can't figure out something; bike usually starts with a kick or two, will run for about 30 seconds to a minute and then bwaaa bwaaa dies! While it runs it reacts perfectly to the throttle. I checked and replaced carb with a known good one. All jets and settings are at stock. Reeds are perfect also. When it stalls, the spark plug is wet with gas. Usually drying and reinstalling the spark plug will start up nicely but with same results. I also notice a small backfire occasionaly.
The one thing that I noticed is that the copper coil on the stator looks like it has overheated in the past (plastic isolation is cracking) and it is actually a little loose in the housing! is this normal or is a short circuit to blame? Any way to test the coil out of the bike? Thanks for reading and thanks for your feedback.
