Looking for some experience with the best staple gun for seats. I have a craftsman and an arrow but neither does a good job of seating the staples into the plastic. Has any tried the electric staplers or the power shot (saw them both at Lowes)?
I have the electric one from Lowes that has the high/low settings. It works OK. If you are only using it for your own seat cover once in a while it worked but if you are going to be installing them all the time I would invest the money in an air powered one for upolstry work.
I used an Arrow electric one from Lowes and it did ok, but it took a couple of trys. It didnt seem to go through the plastic that good. You have to really push down hard but the one about the staplle gun that can go through concrete sounds like the way to go.
its not electric, so it will give your hand a workout. I talked to him and he got it at a local construction supply store called American Construction Supply and Equipment.
I used an arrow manual stapler on mine. The first time I used 6mm staples and had a heck of a time, it came out less than perfect. So I re-did it using 8mm staples and it made a big difference. I think the longer staples had more drive to it.
I am like MikeT. I use a local upholstery shop and they charge me $12.00 and they have the tools to stretch the seat cover as they are putting it on. They use a air powered stapler that cost around 150.00 and does a fanstatic job. I tried about 4 different staplers and they wouldn't even put a dent in the 96 RM250 plastic seat base.
I have always used an arrow t-50 to do my covers. Here's a tip for ya though, to get the staples to go into the plastic good kind of lift the back of the stapler a tiny amount (so basically just the nose touches) it works much much better.
You can buy a air stapler from Harbor Freight for about $40. Get the one with a 1/2" crown. It works quite well. I've tried the electric ones from sears and arrow and they wouldn't push the staple through the plastic base of the seat, where as the Harbor Freight one will seat the staple completely.:)
Inexpensive pneumatic stapler from Harbor Freight & Salvage - I think it's a Chicago Pneumatic brand - that has a 'nose' to get down in the narrow sections. It was ~$50 and makes the job sooooo easy.
Are you guys that are having troubles using staked staples. If you don't the staples try to twist instead of going in. I have no problems with a T50, with the right staples.
You've got to make sure you put lots of downward pressure on the front of the stapler using your other hand before pulling the trigger. This keeps the front from jumping up and drives the staple in harder.
kooade,
what staples are you using in your T-50? I put a cover on my GasGas seat last night with the same staples I used in my KDX seat base and although I got it on nicely I had a horrible time with getting the staples in all the way. The GG seat base must be made of better stuff than the KDX. Just wondering, thanks.
"Get the one with a 1/2" crown"
How long of staples do you guys use? I should hope not 1/2 staples, it would seam to me that they would stick into your.... when you sat down. I have an air stapler that can go down to 3/4" but I have not tried shorter staples in it. I usually use the 6mm T50 staples.
Most staples are made to work in wood. The end of wood staples are sharp and come to a point on the edge of the staple legs. This causes the staple to twist in and lock in tighter. In plastic they twist before they are fulley seated. For plastis you want staples that come to a point in the center of the stalpe legs. The arrow brand staples do not work well. The ace hardware brand works good. The gas gas seat bases are hard to drive a staple in. This is all hared to explain in print.
