Starts
buffmaster
558
I plan on doing some races next year, and have done some research about them here. Just how bad is the "pin it-and-dump-the-clutch-when-the-gate-drops method"? I know it's not as effective as a method that gets minimum wheel spin (wheel spin = less traction), but just how much of a difference is there? I'm asking b/c my father-in-law and brother-in-law, who both have raced(bro' races up until last year), both use the latter method b/c it's 'the only way'. Any help and or tips on this one would be great.
Oh yeah, one day we were all riding at house and 'dad' had us (me and 'bro' ') do starts. We were using the former method b/c that's all we knew. Everytime, whoever got to the first 10' (i.e.- whoever got traction first), won the holeshot.:think
KawieKX125
946
The dump the clutch and pin it technique is auful. Learn to feather the clutch and throttle and control your weight for maximum traction and you will get good starts.
High Lord Gomer
Poked with Sticks
Sep 26, 1999
11,788
35
30% of the time you'll get to watch everyone pull away while you sit there and spin.
50% of the time you'll see everyone pulling away once you get the front end down from the monster wheelie you pulled.
18% of the time you'll get to watch everyone pull away while you pick up the bike after looping out.
The rest of the time you'll blow the holeshot by overshooting the first turn because you're so shocked that it actually worked.
:confused: :scream: :o
smilinicon
95
LOL... been there and done it! I have been doing my best starts by slipping clutch and front brake at the same time. 3/4 throttle then WFO and then put some arse into it to get the rear tire hooked up (after the gate).
Throttle must hit the stops... it's now or never at the starts.
FLBob
210
This caught my eye - I try to ride Hare Scrambles and feel I need to work on my starts because I'm switching from a little four stroke to a KDX220. Somewhere here I read someone suggesting starting out in second gear - sounded plausible, but I haven't had a chance to try it out. Stupid idea?
buffmaster
558
Yes, 2nd is the way to go. 1st has too much ooomph, front end tends to come up REAL easy.
High Lord Gomer
Poked with Sticks
Sep 26, 1999
11,788
35
For MX, I always start in 2nd on a 250.
In HS, I also use second except when starting on a hill. The last HS I did had us starting going uphill for 50 yards, then downhill for another 50 before turning into the woods. 1st worked well for that one.
Jaybird
Apprentice Goon
6,449
Charlestown, IN
1st makes you have to get your feet to the pegs too fast.
Cookies are required to use this site. You must accept them to continue using the site. Learn more…
