I managed to get super stuck in some deep, thick goo. As I ground to a halt, the muck was just a tad over the axles with water maybe another couple of inches. After a tremendous effort (thx Proxy) and nearly a heart attack, we got it out and back on dry land. It would not start, not even close. It wasn't locked and would kick over, but that's all. Closer inspection and it didn't look like water or muck had gotten anywhere near the carb or airbox, as that area and above was clean in comparision to the gearbox and lower. As I waited on the trail for my buddy to return with a tow strap, I noticed that gas was leaking fairly steadily out of one of the drain tubes under the bike. I shut off the petcock, and it stopped. Opened the petcock and it started draining again, so I rapt (with knuckles) on the side of the carb, nothing. Ended up just closing the petcock until help arrived in the form of a two strap. We pulled for maybe 50 yards before it finally sputtered to life, belching smoke and running like crap for a bit, but then was just fine and no more leaks. I found some clear water and washed off the important stuff like bearings, brakes and chain assembly, and then rode quite a bit more the rest of the day, bike running normally.
So, my question, what happened? Why would the bike not start and what could've caused the fuel to run out of the drain hose like that?
Any insight is GREATLY appreciated.... :cool:
