dirtbikr99
180
I have a 99 cr250 i just bought, the oil drain bolt is stuck. I started trying to loosen it, then i couldent get it loose so i got a breaker bar out just to get some more power on it. But i felt i was putting to much force on it and did not want to strip the threads. Any ideas on how to get it loose, heat maybe, penitrating lube?
darringer
1,029
I would try a penetrating oil. Then maybe a little heat from a propane torch around the bolt hole, but not on the bolt itself. Sometimes an impact gun will get it to let go, also.
rm_racer
501
Try all the things mentioned. Also try to tighten it a little, then try to remove it. Sometimes it relives the stress and whats holding it in with out the extra force.
DOTdirtbiker
9
oil drain plug
heat was my answer as well, even if it has a nylon washer (let it melt). My neighbor had a 79 rm 125 and he cranked on the plug. It busted the case. He got the plug off but it took the surrounding case with it. He then (got it apart in a vise I guess) cleaned it and jb welded it and it lasted fine after that.
