Rikster
- Mar 22, 2010
- 22
- 0
Everytime I tried to ride my pitbike (Stomp 140, YX140 engine) my flywheel bolt came loose and the flywheel flew off. I found that it was because it had chewed up a woodruff key before and it chewed up the cranks taper which holds the flywheel in place.
So what I decided to do was smother the flywheel and nut in super glue and technically it shouldn't move. It worked and the flywheel doesnt move at all, but turns out I glued the wrong flywheel to the crank :bang: . It was a Lifan flywheel but I tried to run it anyway and it fires too late, doesn't pull and the exhaust glows red like a lightsaber.
I tried to get it off and managed to get the nut off, but the flywheel is well and truley stuck. Anyone have any super ideas to get it off? Thankyuu.
Edit: Managed to get it off by pouring boiling water over it for 1-2 minutes then levering it off with a big flathead :nod:
