Super Glue Problem. LOL! Please Help.
Rikster
22
Everytime I tried to ride my pitbike (Stomp 140, YX140 engine) my flywheel bolt came loose and the flywheel flew off. I found that it was because it had chewed up a woodruff key before and it chewed up the cranks taper which holds the flywheel in place.
So what I decided to do was smother the flywheel and nut in super glue and technically it shouldn't move. It worked and the flywheel doesnt move at all, but turns out I glued the wrong flywheel to the crank :bang: . It was a Lifan flywheel but I tried to run it anyway and it fires too late, doesn't pull and the exhaust glows red like a lightsaber.
I tried to get it off and managed to get the nut off, but the flywheel is well and truley stuck. Anyone have any super ideas to get it off? Thankyuu.
Edit: Managed to get it off by pouring boiling water over it for 1-2 minutes then levering it off with a big flathead :nod:
Patman
Pantless Wonder
Ever think what might happen if it got hot enough to cause the super glue to fail while you were riding? I assure you if you spend just a little time and effort you could find a better & safer solution.
Rikster
22
True. Its only temporary till I get a new crank but im always ready on the cutout switch if I hear any abnormal pops.
Rikster
22
Its a scrappy pit bike... All I want it for is ripping around some private land with my mates on theirs. Only doing this because its been sitting here for 3 months doing nothing since I also own a KX100 and a DRZ400 which are mechanically perfect.
Im not about to prioritise money for a new crank when i'd rather scrap it in. Im not too fussed if it breaks more as it would get sold as spares and repaires anyway.
Patman
Pantless Wonder
If it's junk then just weld it.
Patman
Pantless Wonder
Silly me.
16,905
You mean the KX100 you have with the weak spark that keeps blowing head gaskets, or the DRZ with the carb problems? :whoa:
:rotfl: See!!! I knew it couldn't be true. ;)
Patman
Pantless Wonder
Well perfect besides those things.
:rotfl:
Rikster
22
haha Stop checking my threads! Those problems have all been sorted, that was months ago. Stop ripping me!! :O
