I am trying to properly set up the suspension on my 2009 CRF450R. I am 5' 11", weight is 198 lbs. (with riding gear), and I am a novice level Vet rider. I ride MX tracks only in Southern California. I do not race - just a weekend warrior.
For the rear suspension, the closest I could get to proper set up with the stock spring is 97mm for RACE SAG and 40mm for FREE SAG. My manual calls for a range of 95-115mm for Race Sag - I am in spec for this.
The manual calls for 10-25mm of Free Sag - I am out of spec for this.
I have tried to adjust the spring pre-load to get within spec for the Free Sag but when I get within spec for Free Sag I end up out of spec for Race Sag.
The manual says that the stock springs are for a rider in the 165 lb range (I do not know if this is with or without gear - the manual does not specify). My bike feels pretty good as is but I do not have a reference point to compare to.
Based on what the manual says and the measurements that I got, I believe that I need a heavier rear spring - is this the correct conclusion?
Any help is appreciated.
