The bike is built in Japan, they don't use SAE bolts over there. ;)
rpm12505
190
O3RM125 said:
Just tryin to save myself a little time and money.. anyone happen to know if the allen bolts on the 2003 rm 125 would be sae or metric? Specifically the brake rotors(same size), and the rear sprocket?
Thanks very much in advance.
When removing rear sprocket hold allen side stationary and brake loose the nut with a box end wrench. Less chance of rounding out the allen bolt.
KiwiBird
2,385
huh, huh, he said "spanners"
Isn't a spanner one of those 13/19ths whitworth things that fit 27/33rd nuts on your MG?
Careful Kiwi - If Bruce can ever get his Royal Enfield started he is likely to ride out there (allowing of course for the 547 stops he'll make to fix the electrics) and kick your butt for besmearching the fine legacy of Sir Joseph Whitworth. :)
