Well I finally did it, been putting it off for far too long. But I ordered a Moose swingarm bearing kit just in case. As if I had any doubts about the bearings?? :eek:
Remember my steering head bearing? (http://dirtrider.net/forums3/attachment.php?attachmentid=3880)
Well I did not have to break out the sawzall, but it had me wondering. I soaked the pivot bolt with WD40 over night, and had me a nice big breakfast in the morning so I could go out and wale on the darn bolt! With the first hit with the sledge, my left hand holding the drift slipped and mashed my hand into the foot peg :silly: Wrapped a rag around the foot peg to cure that.
After about 10 hard blows, I decided to go get a bigger sledge and after another 10 or so blows the bolt actually moved about 2mm! :worship:
So I went and fired up my propane torch and got everything nice and smokin’ hot. I was starting to wonder if I should have taken the gas tank off, having that torch in such a close proximity to it, but I figured too late for that.
Well anyway I went back to the sledge and hey it moved, not much, but enough to get my spirits back up. I got it to move until it was flush with the frame. I guess I should add that I was hitting it as hard as I can at this point. And then I said to myself now what? The drift was larger than the hole for the pivot bolt. The bolt was not out far enough to grab on too from the other side. So I went to the other side and pounded it back in and then pounded it back out and repeated this until it got a lot easier to move the bolt back and forth. Then I dove into my dirty shop looking for something the right size to drive out the bolt, and luckily I found a round bar just the right size. I gave ‘er one good smack and the bolt went flying out. And then I started hearing a sound that reminded me of changing out that steering head bearing. Little metallic sounds of needle bearings falling to the ground!
Well that’s about as far as I’ve got . I cleaned everything all up and the only bearings that look really bad are the swingarm(of course) and the lower shock bearing, the rest look pretty good, I have a kit to replace everything, but I may just replace the bad ones for now. I dunno
Gonna replace my shock spring. So I figured I’d replace the oil in it too. I went to let out the nitrogen out of it and all I heard was a little pssst. Man there could not have been a pound in there! Guess I’ll probably be ordering a new bladder for that...
