Well, after riding both the TTR and KX100 today at our local dealership, my wife is definitely set on the KX100. The TTR was so slow compared to the KX to say the least. At any rate, I'm looking to set this bike up for trail use, so here's what I'm looking to buy, and I need help finding the companies that make these parts for the KX100:
1) Full Coverage Skid Plate
2) Full Pipe Guard for the stock pipe
3) Hand guards - the kind that connect at the end of the bar with the plastic deflector
4) I've already decided on the Steahly Flywheel weight unless someone has a better recommendation.
5) I can't decide whether to lower the front sprocket one tooth, make the rear a couple of teeth larger, or do a combination of both??
6) I'm probably going to back out the rear suspension all the way, and depending on the increase amount of squat, I'm probably going to slide the fork tubes the equivalent distance to bring it back to stock levels and make it a tad easier for her to ride in the beginning.
7) I've also heard of a way that you can limit the throttle to 2/3 or some amount, but I'm not clear on what product this is and who makes it.
8) Does anyone make a light kit for a KX100?
9) Does anyone make an aluminum radiator cover, protector, and frame guards for this bike?
10) Does anyone else have any other recommendations for parts that would make for an awesome trail bike?
I really appreciate the help on this, and I can't wait to hear everyone's responses.
Chris
Chris
