I have a 01 tm 250 MX and I am having problems with my clutch. When I try to pull in my clutch lever in it locks up solid. I can pull it hard enough to where I blow the O-rings in the slave cylinder. This is the 2nd set of O-rings. The hydraulic slave cylinder works fine when off the bike. Moves out just fine. I took the clutch apart and it looks fine. I can't figure it out. I replaced the O-rings and took apart the clutch and put it back together and it worked fine on the stand. I went to a race today and the clutch worked fine for about a 1/4 mile and then the lever locked up. I squezed it hard enough in a rage and blew the O-rings again in the slave cylinder. What can it be. Need your help!!
Chris
Chris
