c-squared
4
I've read where some have been able to fabricate the 50mm cap wrench, just wanted to know how you did it? I keep looking at 3" flat bar stock at Lowes thinking I can cut the pattern with a Dremel, but experience tells me that it would likely be a lot harder to do than I think.
Before I shell out $28.50 + shipping to Atomic22 I wanted to check to see if there was an easier and more cost effective solution. I've already learned my lesson on prior bikes with cresent and pipe wrenches.
Thanks for any help.
JTT
1,407
I made mine out of 1/8" aluminum plate. I simply scibbed the shape (you could even trace it off the cap and cut slightly smaller), drilled a small hole at each corner and used my dremel to cut between the holes. The whole process took about 1 hour including handfiling to clean up edges. It is a little crude, but I was in a hurry and needed the tool.
Always planned on making another a little cleaner, but the first one works perfect and have had trouble justifying spending any time at it.
I would suggest the aluminum though, it's much easier to work with and there is almost no chance of it damaging the fork, as it is softer than the actual nut. There is very little torque to contend with so the aluminum one is more than strong enough. It also does not really need to be highly precision either, so don't panic if you make a small booboo.
Good luck
FRESH VIDEO
