I use Belray 80w gearsaver in my tranny. I've been chasing an excessive smoking problem for a while now with no luck. I've got it down to either a jetting issue or a leaky crank seal.... I think. Anyway, it hasn't got any worse nor have I noticed anything different, but I noticed while looking through the sight glass that the oil had turned pink and milky. Now I just recently did the oil change and there is a variable....the oil change before this last one was at the track and all I had access to was a regular 5w30 synthetic. I only rode for maybe an hour on that oil. Now when I did this most recent oil change I did it cold. I didn't run it to temp first I just drained it cold and went back with the gearsave 80w. Could it have just mixed with the brown 5w30 that was left in the case to make the milky pink ? Or does it sound like it's mixing with coolant ??? And does anyone know the easiest way to determine if the crankseal is bad ????
