Ok...I know this has been beat to death, and I did look over past postings and could not find an answer to this: I drained the gear oil out (that was probably causing the clutch drag when cold) and was going to try automatic transmission fluid. I got Mobile 1 synthetic ATF fluid. I hear alot of guys are buying type F, which is apparently for older vehicles....do you have to use type F for some reason??. Are there any gears in an automatic?? I did not think so...well maybe the pump. Will ATF provide enough film strength to protect transmission gears.? I never thought when I purchased this bike my biggest issue would be tranny fluid :yikes:
