125 rider
408
My manual calls for 10-w30 in the tranny. Right now i have 10-w40 in it. Would it be ok to put 20-w50 in ? Would that result in different clutch behavior? I am only tempted to use it because there is a 5 quart container of Castrol GTX (no ec) sitting in my basement that my brother uses for his ninja which would be quite convenient for me.
itsamelee
39
i just use streight 40 weight ,,,it is roughly the same thickness as 80 w 90
the only difference is the price
if im wrong someone please correct me !
gotta go
125 rider
408
Are you sure? I think 40 weight oil is the same thickness as...well, 40 weight oil. 80w-90 is thick gear oil. When an oil has two numbers i.e. 80-w90 it means the viscosity when cold and the viscosity when at operating temp. If it has one number i.e. 40, it does not have the polymer additives to help it from thinning at high temp.
spanky250
Mod Ban
Dec 10, 2000
1,490
Engine oil and gear oil are not rated with the same sytem. 80w gear oil is approximately equivalent to 30w engine oil as far as viscosity is concerned.
