Trouble starting - Ignition Coil
mstone
13
So a few weeks ago my 92 kdx200 and I went for an afternoon swim and the bike has not been the same. It has been extremely hard to start. So I ran through the electrical system tests and my ignition coil is not reading the proper resistance on the primary winding( .3 and should be 1 +- .15 ). So my question is, where can I get an after market coil. Looks like $60 for OEM. And, are there any other bikes that use the same coil.
David Trustrum
1,396
Um assume you drowned the bike, it can cause more problems than obvious.
What did you do to clean it out? Is the tranny full of water, the airfilter junk? The carb jets blocked up (ie pilotjet for starting). Plug & Cap replaced?
