Ok Guys. I Don't Know Why And Can;t Understand Why Two Strokes Performance Has Not Been Improved Via The Size Of The Expansion Pipe.
By This I Mean....when You Look At Dynos Of 125's With A Dented Pipe And One Of A Normal Pipe, The Dented Pipe Has Advantages For Top End And The Undented Pipe Gives More Bottom End But Less Top End.
So....why Has No One Tried To Make A 2 Stroke With 2 Expansion Pipes, Both Different Sizes, And 2 Controleed Exhaust Ports. This Way Both Pipes Can Be Opened To Begin With, Then As The Revs Go Up, The Smaller Pipe Will Cut Off First, Giving More Power At That Rev Range. Then At Higher Revs The Pipes Swap And The Smaller One Is Used.
Surely This Way A 125's Power Can Be Increased Even More, It Will Have More Power All The Way Up The Rev Range And Could Be Perfected If People Advanced It.
I Am 16 And This Is A Wild Guess But It Makes Sense To Me. Any Thoughts???
