Uechi45
44
I just destroyed the stock headlight assembly on my KLX and have a UFO version waiting to put on. My question is there are two bulbs in it. One is a 10 watt "dome" light which is useless, but the other is a 35/35 watt Hi-Low beam set up. Should I wire it so that both beams come on or only one? If I have both on will I melt the plastic housing? UFO does not have a phone number in this country and of course no instructions come with the unit. Also is the stock winding on the KLX powerfull enough to light both Hi and Low at the same time? Is there a replacement single element bulb for this unit with more wattage than 35? Any help will be appreciated.
penguin
390
wire both bulbs to light up at the same time. The KLX is based on a Japanese home market dualsport and the lighting coil can handle the load just fine.
