It seems that nobody makes stiffer fork springs than .46 for a '00 KX250.. I need approx. .50 rate springs. I think the difference can be made up with valving but I think that a better valving job could be done with the correct rates as a starting point. Does anyone know where I might find fork springs this stiff?
I've got a 6.0 on the rear which is fine, for some reason nobody seems to make fork springs to match their stiffest shock springs. It seems that .46 fork springs should be generally matched to something close to 5.4 - 5.6 on the rear.
Thanks..
Cam
Thanks..
Cam
