ropethebike
54
and where can I get them. I will assume I could get them at the Suzuki dealer, but it might help if I knew what they were called.
On the top left side of the cylinder, the "thing" that appears to be pressed into the cylinder head with the vent hose attached to it. I think there is also one on the other aide too, but it isn't leaking
Mine is leaking and I want to replace it.
rtb
IndyMX
Crash Test Dummy
5,548
Amo, IN
That's not a "vent" hose... That's most likely the radiator hose.
Are you sure it's not just the radiator hose that's loose?
ropethebike
54
No, not the radiator hose. On each side of the cylinder, maybe its the cylnider itself, not the cylinder head) these little fittings have the small (size of a straw) hoses that run down and hang out the bottom......the alum. cap that the hose is attached to is pulling loose from the brass looking stud that looks like its pressed into the cylinder.
When I say leaking,its really not fluid, its just black spooge kinda gooing down the side of the engine, instead of the clear hose
sorry I wasn't very clear with my original post and thanks for replying
rtb
Rotorranch
436
Click here for: '04 RM125 microfiche
Part #9 is what I think you are talking about.
Rotor
Rotorranch
436
Description BikeBandit.com
Part Number Quantity Unit Price
1-2: HEAD, CYLINDER 1767748-001 Invalid $100.81
1-3: HEAD,CYLINDER 2515175-001 Invalid $100.81
1-4: HEAD,CYLINDER 3625884-001 Invalid $100.04
11-1: GASKET,CYLINDER
(MODEL K3NOT SHOWN) 3099609-001 Invalid $7.28
11-2: GASKET,CYLINDER
(MODEL K4/K5/K6NOT SHOWN) 2515202-001 Invalid $7.25
17-1: NUT
GREEN 2558-001 Invalid $1.15
17-2: NUT, CYLINDER 1816809-001 Invalid $1.26
20-1: BOLT
BLACK 2562-001 Invalid $1.26
20-2: BOLT,6X16
L:18 1474944-001 Invalid $1.08
23-1: SCREW 2568-001 Invalid $0.85
23-2: BOLT,CYLINDER C 1757732-001 Invalid $1.08
24-1: HOSE
(9X14X220) 2569-001 Invalid $6.06
24-2: HOSE
5X8.2X600 473053-001 Invalid $5.62
29-1: NUT 10MM 2680-001 Invalid $0.89
29-2: NUT 469218-001 Invalid $1.52
6A: PIN 4X8 2692-001 Invalid $0.59
8-1: CYLINDER SET 476109-001 Invalid $491.32
8-2: CYLINDER SET 1757767-001 Invalid $491.32
8-3: CYLINDER SET 2515184-001 Invalid $491.32
8-4: CYLINDER SET 3626209-001 Invalid $487.98
9-1: UNION BREATHER
(MODEL K1/K2/K3MODEL K4/K5/K6) 2550-001 Invalid $9.94
2: O-RING,CYL HD # 2539-001 Invalid $5.65
3: O-RING,CYL HD # 2629-001 Invalid $2.95
4: NUT 2541-001 Invalid $2.48
5: GASKET 8.5X17X2
8.5X17X2.3 2542-001 Invalid $1.26
6: STUD BOLT
(8X38) 2543-001 Invalid $1.74
7: SPARK PLUG R691
NGK,R6918B-8 2544-001 Invalid $23.44
10: UNION,ROOF DRAI 2551-001 Invalid $3.11
12: BOLT,STUD,L:33
8X33 468259-001 Invalid $1.63
13: STUD BOLT L:30
L:30 2554-001 Invalid $1.63
14: 8 X 35 STUD BOL
8X35 2555-001 Invalid $1.15
15: STUD BOLT L:40
L:40 2556-001 Invalid $1.63
16: PIN
11X14 2557-001 Invalid $2.81
18: COVER,CYLINDER, 2559-001 Invalid $16.52
19: GASKET,CYL COVE 2560-001 Invalid $4.22
21: COVER,CYL,NO.2 2564-001 Invalid $16.04
22: GASKET, CYL COV 2634-001 Invalid $3.11
25: CLIP 2570-001 Invalid $1.15
26: FILTER,EXH VALV 2571-001 Invalid $7.17
27: HOSE,5X8.2X600
L:600!360 2572-001 Invalid $4.44
28: BOLT 10X47.5
10X48 3205-001 Invalid $1.96
30: CLAMP,WIRING HA
L:165 3554-001 Invalid $1.11
rpm12505
190
Take it out, clean it well and JB weld it. And/or very slightly peen the hole in the casting to make it fit tighter. It's worked for two years so far on my sons bike. Good luck.
