import_eater
20
im 15 years old, im about 5'6 and 150 pounds.. would i be able to ride a cr125r without probems? or wouldnt i be abel to handle/ fit it? :think: ? let me know wat yall think
robwbright
2,283
I'm 5'4, 140. I'm doing just fine on my RM125 (144).
Starts are a bit tricky - I've gotten a couple bad ones because of being unbalanced on the gate - I can rarely get both feet to touch, even tiptoe. Otherwise, no problem. Well, there is one other problem. Woods riding gets a bit tricky when you're on a slow off camber corner, make a mistake and start to fall to the downhill side. :think:
Anyway, you can always cut down the subframe and/or seat to lower it 1-2 inches, or spend lots of $$ and lower the suspension. I doubt you'll find it necessary though. I'll cut my seat when I buy new seat foam. Till then, I'm riding it as is.
import_eater
20
cool so a 125 should fit me perfect... cuz im bout 2 inches taller than u and like 5 10 pounds more... soo ill go check out sum 125's probabally a cr125r! :cool:
