What special tools needed to split the cases
rsrxc700
18
I want tackle splitting the cases on a 96 CR 250 to change crank bearings/seals. I already have a flywheel puller.
Do I need the Motion Pro Crankcase Separator tool, or can I just use a standard universal puller? How about installing, do I need the Honda tool?
Will I need a press to get the bearings out, or can I just heat them up and gently "persuade" them?
Will they go back in if I put the bearings in the freezer w/o a press? I know I do not want to hammer on them.
Any help will be greatly appreciated!!!
Thanks!
RSR
darringer
1,029
I have always been able to carefully split the cases and re-assemble without any special tools. As far as bearings, I have had good luck putting one side case at a time in a cheap toaster oven, heated it up until water sizzled off the case when dripped on it, and have the bearings drop right out. For replacing the bearings, heat the case the same way, and use bearings that have been in the freezer for about an hour. If they don't drop in, very light tapping always works. Good luck.
