Dozza
12
Hey,
Well me and my brother have never had motorbikes and we'd like to get one. Nothing serious though like racing, just something to muck around on up at this paddock place near our house for fun.
Now, I'm going to have to copy and paste the specs of them because it won't let me post links...
Here's one:
Wave Disc Front, Wave Disc Rear, Quality LIFAN Engine, Heavy Duty Shocker, Nylon Chain Runner, Polished Fuel Cap, Big Bore Power Pipe and Polished Alloy Swingarm. Here's the other stuff:
Engine: 125cc, single cylinder, 4-stroke, air-cooled
Ignition: CDI
Start-up: Kick Start
Drive system: chain-driven
Wheels: 12" Front and 10" Rear
Fuel tank: 3L
Speed: under 90km/h
Fuel Usage : approx 65kms
Wheel Base : 1130mm
Seat height: approx 770mm
Max load capacity: Recommended MAX 95KG
Dry Weight : 60kg
Exhaust: High Performance
Heavy duty extended front forks
Colour Coded Wheels, Bars & Bash Plate
Power Pipe with ALLOY Muffler
Spring Loaded Gear Lever
Alloy Swingarm and Tripple Tree
Heavy Duty Adjustable Rear Shock
Foam Sports Air Filter
Wave Disc Rotors
Upgraded Knobby Tyres (Not Cheapies)
Nylon Chain Runner (Not rubber like cheap bikes)
And here's specs of another one but it doesn't ship until the 10th of Feb.
DUCAR 125cc 4 Stroke Single Cylinder Air cooled
Manual (International 1 down 3 up)
Kick Start and Electric start
18mm alloy sport muffler
26mm Carburetor
Adjustable HeavyDuty rear Mono-shock
Colour: CARBON FIBRE
MAX SPEED: 100km
BORE*STROKE: 52.4mm x 55.5mm
SEAT HEIGHT: About 750mm
WHEEL BASE: 1100mm
TANK CAPACITY: 3Litre
Quality Front and Rear Hydraulic WAVE Disc Brake
FRONT/REAR WHEEL SIZE:2.15X14"/3.0X12"
PRODUCTS SIZE:159X67X100cm
CARTON SIZE: 138X42.5X70cm
G.W/N.W: 78KG/65KG
Max weight capacity:100kg
NGK SPARK PLUG
Sports Air Filter
Heavy duty bearings
Reliable Quality throttles and handles Grips
Improved heavy duty KMC chain
Telescopic front fork
Aluminium Head set
Engine bash plate
As you can see we don't want to spend heaps. It's not for racing or anything remember. The first one is $575 AUS and the 2nd one is $600 AUS So I think they're quite cheap brands but do you guys think they'll be fine?
Thanks.
DrDuDe
10
Pitster Pro bikes kick butt! I don't know what your talking about but i race a ton of pitbikes and work for a Pitster pro dealership. We have carried several diffrernt brands and actually dropped them all after having Pitster Pros because nothing else compares. I'm 6'2" 180lbs and ride those things just fine. They also take alot of abuse. Im a intermediate rider and bagged one of those bikes all last year and never had any problems.
Moose
1,091
Wouldn't get the knock off bikes, because eventually you'll break a part you'll never find. PitsterPro's have good part availability.
A couple of guys also landed backflips on them too, a while back.
Dozza
12
I've been looking at the Pitpro's (is that the same as a Pitster pro?) and I might try and bid on some later.
Anyway do you guys know about a 07 Model MXB ALLOY MX PRO 125cc Thumpstar?
Here are its specs:
Specifications
* 4 stroke Loncin silver motor
* Manual clutch 4 gears
* Upside down forks
* Rear adjustable GAS Shock
* Performance Exhaust System
* ALLOY parts
* ALLOY Exhaust
* ALLOY Handle bars
* ALLOY Triple Clamp
* ALLOY Fuel Cap
* ALLOY Bash Plate
* ALLOY anodized rims
* Wave Disc Brakes-Front and Rear
* 14” Front Wheel 12” Rear Wheel
* Light Weight Frame
* Japan Carburetor “JING HUA”
* Electric Start
* Improved Gear Shifter
Would this one be any good?
rushy08
235
none of them are going to be 'good'. get a klx110 and bomb it if you want good. oh yeh and drdude you didnt have to tell us you worked for a pitpro dealership mate, from the wrap you gave em we could tell
