maliboost
18
hey, have a 91 kdx 250
lost a rear bearing, tore up my hub, the jbweld seems to be holding ok for now but I would like to fix it right
my wheels are pretty bad as it is, bent or eggshaped they ride like crap on the street but its ok off road
i would like to swap over to a normal mx rim, does a kx wheel fit, i would like to swap front and rear, does anybody know?
on a side note, I'm so excited to be riding this, i broke it almost 2 years ago right after I bought it but me and a buddy fixed it and I have been out riding it, it's a blast, my buddy says it hauls ass just as much as his 99 rm250, which i doubt but it is still fast enough to excite me which is really a surprise because I have a 250 or so hp streetbike, going fast in the dirt is way different than on the street
maliboost
18
Turbo zx9. I built it.
dirt bike dave
5,348
Wow! That is an amazing bike. Just seeing the pictures gave me an adrenaline rush.
As for the KDX250 hub and wheel, if no luck finding a '91 - '94 KDX250 hub, you might look into a KLX250 or 300. Possibly a very late '80's KX250, too. With any luck, maybe a common KDX200 hub will work.
I'm not sure if any of these will fit, but they might be worth a shot. You might want to call Jeff Fredette at Fredette Racing Products. He will probably know what hubs will be suitable replacements.
Oh, and you can also view parts diagrams and numbers at www.buykawsaki.com
maliboost
18
Yeah it's a rush. Kinda like riding a 2 stroke the way the power comes on. It's fairly tame until it spools then it's like the hit that a 2 stroke gets
what makes hubs different. I know some have different axle diameter I was just wondering on the sproket and disc lining up
maliboost
18
i'm going to have to look into this, i havent looked to see if there are more tire options if i switch to an inch larger wheel but I imagine so
ridejunky
340
rear yes
craig_enid
Registered
I picked up a '95 KX 125 basket case and was able to bolt it's rear tire/rim/hub straight onto my 200H, 220A model KDXs. I could not tell any difference in the handling, although I've heard a good rider could. Also using the 35mm AS carb.
front?
dont think so, you will need spacers etc and I don't thin the caliper will lign up
glad2ride
1,071
Look on the parts diagrams on the Kawasaki site under Owner Info / Parts Diagrams. If you click around, it will show what other models had the same hub. Be aware of rim size if you shop for a whole wheel.
Good luck with it, and cool Ninja!
maliboost
18
well my buddy has an late 80s kx125
i looked up the diagram and the spacers and the axle are the same hub shows same part number, maybe once we are done for the season i'll steal his wheel and see if it fits
ridejunky
340
The kx doesn't have a tripometer
maliboost
18
well, took it out today, had a blast, really beat on it, blew another rear bearing. jb weld is holding fine, but i'm done messing around, i'm going to replace the whole hub/rim
I got to taking apart the rear end just decided I was going to keep going
sr5bidder
1,463
maliboost said:
started sanding it, think i'm going to try using spray on bedliner on the frame
why :whoa:
I used duplicolor truck paint pewter looks better than green to me but to each thier own
<a href="http://s375.photobucket.com/albums/oo195/sr5bidder/?action=view&current=IMG_1738.jpg" target="_blank"><img src="http://i375.photobucket.com/albums/oo195/sr5bidder/IMG_1738.jpg" border="0" alt="Photobucket"></a>
maliboost
18
this is what i got, figured i'd post it in case someone else needs it
the rear hub cross references to
1995-2006 KDX200
1997-2005 KDX220R
1991-1994 KDX250
1994-1996 KLX250R
2006-2007 KLX250S
1997-2007 KLX300R
1993-1996 KLX650R
