jack10525 said:Also this may be a really dumb question but, do you need to take the engine out to do the topend?
Nope.
Melenko said:What happens when you forget to aligne the power valve linkage properly?
kxmike said:i did my first top end 2 weeks ago and it is really easy. i thought it was going to be hard but it was a peice of cake. i think the harest thing is tourquing the bolts back but ft lbs torque confuses me.
James980 said:The powervalve won't work.
But there's a trick to it that I discovered on my second or third set of rings on my 2000 CR250 that makes it real easy on that bike.
Leave the powervalve cover off and start dropping the cylinder down on the piston. When you have an inch or so to go before the cylinder is fully seated, losen the nut on the shaft of the actuator arm and pull out the cotter pin. The arm will slide partially down out of the cylinder and you can line it up on the pin sticking up out of the bottom end. Then, just fully seat the cylinder, make sure the powervalve linkage is in the right position (fully closed), torque the nut and put the cotter pin back in.
Simple as pie!
mxmatthew said:just a question about the forged pistons; when I did a topend after I bough my bike used the piston skirt was cracked so maybe a forged piston will give me a little more peace of mind. I remember hearing that with a certain kind of piston you have to make sure you warm up your bike really well becase these kind of pistons expand very quickly. Is this talking about forged pistons?
take your kickstarter and push down with hand, and if youFrontside720 said:200 hours!!! SWEET!!!
I won't be racing but I won't be putting around either. I'll be riding once a week (2x's if I'm lucky)
So once a year should be fine.
How do I no I need to get one done before I blow my engine?
SoFlo said:With the Wiseco I was using, the rings spin around the piston really easy.
