IndyYZ85 said:That would make it too easy to hit neutral when you don't want to...
I can almost never hit neutral, unless I don't want to.
76GMC1500 said:This is so true. The neutral is small, though, because how often do you really need to hit neutral? Maybe, when you're trying to start the bike after you've dumped it, but that's about it.
Yz250JdT250 said:What?? Clutches are never designed to drag. That puts a lot of extra stress on the transmission for no reason.
--so does that mean that feathering the clutch puts extra stress as well?
As I said previously, if your adjustment is correct and the cable is moving freely, you'll have to pull the clutch to find out what the problem is. It's not very difficult, but if you don't have the tools or ability, you'll have to take it somewhere. I sympathize with your situation. I too was once young and broke, and so was my bike. On the bright side, it's where I started to learn to fix all things mechanical.sixds said:the clutch has the right amount of play. i dont know what to do now.
Bent6 said:Maybe it's all in my head, but all of my Yamaha's have been hard to get into neutral. Both my '95 RM250 and '03 CRF450 were easier to find neutral. Even my Warrior quad can be a PITA to get into neutral. I think it just the nature of the beast :ride:
LBRaptor said:heres a noob question (i think) sometimes i find it hard to shift into second but sometimes i dont, so, does rpm have anything to do with the easiness of shifting? If the clutch is in shouldn't it not matter?
