Wrench for '01 compression adjuster[KYB]
MXN4FUN
168
Does anyone know where the the wrench for removing the compression adjuster on the new YZ shocks can be obtained? Time to change fluid but can't locate a source for the wrench. Part number would be helpful also. Thanx in advance.
I'm in shape....Round is a shape.
KiwiBird
2,386
Scotts in Montrose CA 818 248-6747 has them.
marcusgunby
6,450
You know the plug wrench you get with a CR or maybe KX -i just cut and filed the head part to match the shape of the comp adjuster-works perfect-i warm the adjuster first to break the threadlock and dont forget to drill the peens.
DesertDog
18
I use a tool from Kowa Seiki, it is a clutch hub nut socket for old honda atv four stroke crank shaft nut removal socket, it works great, K&L supply Co. sells the kit, the part number for the set is 35-9458.
Be real careful removing the compression valve, and make sure you grind the ping dents out, or it will ruin the treads when you screw the valve out !!!
[This message has been edited by DesertDog (edited 04-20-2001).]
