is it worth getting an xr80's crank rebuilt? the rod has side to side play and i can wiggle the main bearings side to side with the crank out of the cases. the bike before i tore it down would run badly n break up and pop n backfire. it also ran unconsistantly reving up and down but i suspect it had an airleak and it always had a wierd sound from the lower end. the compression it good and valve seem fine cam chain n sprockets are fine cam lobes r fine rockers are good. cylinder is good. i need a clutch or at least the gear behind it and a crank or crank rebuild. please help me this is my bros bike and it will be my play bike. i suspect also the points could be off. how do i set them? i really dont want 2 sink $ into it if im just doing things and experimenting w/ a $200 crank and $100 clutch and lke $100 worth of gaskets. could an air leak on the intake like just after the carb cause the crank to go? i also ahve a service manual.
