G'day All,
Our local MX club recently modified one of the table-tops on our track so that it has a steeper up-ramp. This has resulted in higher but shorter jumps for a given approach. That's OK, except now if I don't hit the up-ramp hard enough to make the distance to the down-ramp, the resultant drop will cause my forks to bottom out hard. This happened when I tried to reach the down-ramp a couple of times but hurt my wrists so much when I bottomed the forks that I thought discretion was the better part of valour and stopped trying.
I weigh about 95kg (210lb) and the forks were set up by RaceTech for the previous 85kg (185lb) owner. I know that a set of springs is probably the go but I would like to either change the fork oil or oil level (air-gap) first but I'm not sure which I should try.
Can anyone suggest the ramifications of changing to heavier weight fork oil vs. changing the oil level, particularly in relation to the bottoming problem and the overall fork action.
Any help would be appreciated.
I forgot to include that the compression settings on the forks are at max and I'm using standard weight fork oil.
Also, apologies for posting in the wrong area but, having realised, I can't delete this post and I can't move it either.
