Guys,
I've been having Waterpump splooge from the weep hole and I've currently working on it. First, I was waiting on parts and then work was waiting on me to do other crap. So I'm finally into the Waterpump area of my 520 EXC. I removed the waterpump cover to find a nasty surprise of more waterpump splooge. Keep in mind that this motor only has 150 miles on it.
First here's a picture of the waterpump weep.
I've got a collection of some sort of slippery oil like substance in the bottom of my waterpump housing. I'm not sure what this stuff is. It looks like a mixture of oil and radiator fluid to me. I could be wrong about that though. Any ideas from the worldwide internet gurus? Actually if you look close you can see that the holes on the body of the propeller also has some of the gunk on it. I'm using Silkilene Pro Cool with a dash of water Wetter so maybe I'm getting some sort of nasty reaction. I'm kind of doubting that, but its a possibility. I've always had excellent results with Silkolene products before so I'm surprised at this development. I hoping Darr will tell me exactly what this gunk is made of.
If you look at the lower cavity that's below the waterpump chamber, its completely clear of any gunk. This is probably a high flow area and immune to settling but the water pump area has the gunk sticking on parts that aren't exactly on the bottom of the housing.
This is not the greatest picture but it does show what looks to be some sort of contamination of my 520s oil supply. Its got way to many bubbles for my taste. I'm wondering if I'm also getting radiator fluid into my engine from the waterpump seal area.
Later,
Concho
Later,
Concho
