This info is directly from the 2001 M/XC & E/XC brochure:
- The MXC ignition is listed as "Kokusan 2K-2, Digital Control, w/Lighting Coil, 12v 110w."
- The EXC ignition is listed as "Kokusan 2K-3, Digital Control, w/Lighting Coil, 12v 110w."
This is the same for all of the two stroke models of the MXC & EXC.
- The EXC transmission is listed as "6 Speed EXC, wide ratio".
- The MXC transmission is listed as "6 Speed, MXCclose ratio".
Interestingly, the 250 and up MXC's (not counting the four-strokes) are listed as "SX, close ratio". The four stroke MXC's are listed as "EXC, close ratio".:think
There are no differences in the description of the suspension. Both say the same:
- "Front: WP-USD 43 MA"
- "Rear: WP-PDS-shock absorber".
The power valve controls are listed as follows:
- Both models just say "SDS".
Hope this helps.
